luisdimas's avatar
luisdimas
Follower
Nov 29, 2020
N450 very slow speed in wifi and lan
I have contracted 100 Mb with xfinity but I only get 7 to 9 Mb. My ISP says that they have a good connection with my computer, their signal arrives well. I've already done all the troubleshooting like resetting the device, changing the MTU size, packet fragmentation, DNS. Power levels are fine.
What can I do to improve the download speed?
Version V3.01.22
1 Reply
  • michaelkenward's avatar
    michaelkenward
    The CG3000Dv2 is pretty old (2013) for cable modems. Cable technology has moved on a lot since then.
    If you changed to faster Internet with the modem in place, you should reset the thing and set it up from scratch. It has to forget the older settings from your ISP.
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Cable Modems & Routers
