Reply
N600 Router Model WNDR3700v3 not connecting to internet
Please_Help_Me
My N600 Router Model WNDR3700v3 which had previously worked is no longer connecting to the Internet.  The Internet port light (in-between the Power and 2.4 GHz indicators) is a slow flashing amber light, not green.
I have followed the troubleshooting instructions in the proper sequence and also have resorted to using the "Restore Factory Settings" button.  All to no avail.
I know the cable from the router to the modem (ubee from Timewarner Cable - my ISP) is good because when I bypass the router and connect the cable directly to my Dell Inspiron 15R Windows 10 computer it connects fine.
Your assistance is appreciated.
Thanks
Message 1 of 3
Accepted Solutions
Please_Help_Me
Re: N600 Router Model WNDR3700v3 not connecting to internet
Thank you for your input.  Ended up buying a replacement.
Message 3 of 3
All Replies
Retired_Member
Not applicable
Internet.....Internet setup...select .....Use Computer MAC Address..........reboot modem and router
do this using same PC which you used without router
Same problem........ I would replace the router
Message 2 of 3
Please_Help_Me
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2880 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
