Reply
Highlighted
Follower
NETGEAR router getting too hot
My NETGEAR router is getting very hot when on. The router I have is a WNDR3300 and the powersupply is a 332-1006-01. How can I fix this?
Message 1 of 2
Highlighted
Prodigy
Re: NETGEAR router getting too hot
What I did to mine is unscrew the router up and drilled holes on top of the upper plastic casing and then put the router together and screwed it together. You could also put heat sinks with heat thermal glue on the chips that are getting hot and also drill holes on the upper plastic case.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2593 views
  • 0 kudos
  • 2 in conversation
Announcements
