Reply
Need help on opening UDP ports oh my r6220 Wi-Fi router
CANDYMAN69
Follower
I am in the process of installing a Sprint mobile signal booster. As part of that installation, I need to open UDP ports 53, 67, 500 and 4500 bi-directionally
    Need some help on how to do this, I have no idea where to start!
Model: R6220v2|AC1200 Smart WiFi Router with External Antennas
Message 1 of 2
antinode
Guru
Re: Need help on opening UDP ports oh my r6220 Wi-Fi router
> [...] a Sprint mobile signal booster. [...]
   Not a very detailed description of anything.  Has it a model number?
> [...] As part of that installation, I need to [...]
   Says who?  Are you following some set of instructions?  (Thanks for
the helpful link?)
> [...] I have no idea where to start!
   The product documentation is usually a good place.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Port
Forwarding"?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 343 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
