- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Net Gear AC1750 R64000-100NAS Firmware V1.0.4.106
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 300 Mbps service to my modem. I speed check directly from the modem and I get 300 Mbps, but only get 90 Mbps from any lan connection on my router. Qos speed check gives me 1.5 Mbps. Suggestions on how to get higher speed on my LAN connections.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well I would have never guessed that two cables ( original) and substitute cable were both CAT 5. Rounded up another cable (CAT 6) and bingo success. Thank you for guiding me through this project. Now have 300 Mbps on all LAN connections. Kudos!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Net Gear AC1750 R64000-100NAS Firmware V1.0.4.106
have you checked to see if you're actually getting a gigabit connection from modem----router?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
if not, try replacing the cable between the 2.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
not sure if screen shot went through, but every thing on my internet status page shows about the same as the example you sent. I have tried another cable and the results are the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
for some reason you're only pulling a 100mbps link speed from the modem.
I know you tried a different cable but was it a cat 6 cable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it was something simple and you got it back up and working right!
You might mark it solved so others don't try to fix an already fixed issue 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cables have a nasty habit of failing. Usually at the most inconvenient time.
If you have ever tried to make your own cables, you can see why. Not the most foolproof design you can think of.
