- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear A6210 AC1200 wifi adapter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello folks,
Just upgraded from Windows 7 to 10 and now get errors when trying to activate AC1200 adapter.
Do I need to download new firmware?
Problem is I can't without internet so I guess I need to move my desktop close to modem and connect via cat5?
Is this AC1200 good or should I take a trip to Stapled and get something better?
Thanks and think snow!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK
Figured it out
Need to first clik "REMOVE" to remove all existing adapter software in computer
Then clik install to install software
then plug in the adapter
then choose wifi and enter password
Whew, that was annoying but glad it works now...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear A6210 AC1200 wifi adapter
You have to install the drivers before installing the usb device.
You do have the option of downloading the drivers on a different pc and transfering them via jump drive/flash drive to your current pc.
Or burn them to a cd/dvd.
Or moving it and hardwiring it in for setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK
Figured it out
- Mark as New
- Bookmark
- Subscribe
- Permalink
glad to hear you got it working.
