× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Orbi RBK40: Purple Light / dropping WAN connection
benhaldenby
Tutor
My Netgear Orbi is plugged directly into my ISP's fibre router, and multiple times per day the Orbi's purple light comes on and drops its connection to the WAN. I can't find any information about why this is happening, my ISP can't tell me. I bought the Orbi in May 2017 so it's getting old, is it just failing?
Thanks
Ben
Message 1 of 6
Guru
Re: Netgear Orbi RBK40: Purple Light / dropping WAN connection
Is your orbi in access point mode?
Or the ISP's router in passthrough/modem only mode?
https://kb.netgear.com/30186/What-is-Double-NAT
Message 2 of 6
benhaldenby
Tutor
No, I don’t think it’s a double NAT issue
The Orbi is set to Router Mode.
Not sure about the ISP router, I don’t have the admin for that, but pretty sure it’s in modem only mode.
Message 3 of 6
antinode
Guru
> [...] my ISP's fibre router, [...]
   Not a very detailed descrition of that device.
> Not sure about the ISP router, [...]
   I'd guess that only one of us can see it, which pretty well
establishes the possible directions of information flow about it.
> [...] pretty sure it's in modem only mode.
   "pretty sure"?  Swell.  If you want some actual evidence, then you
might peek at the IP address of the router's WAN/Internet interface.
   Plug that address into the form at: https://whois.arin.net/ , and see
if it is a public or private address.
Message 4 of 6
benhaldenby
Tutor
Fair point. The Orbi router has my public IP address as assigned by my ISP so I'm assuming that their fibre router is in modem-only mode and the Orbi is set up in Router Mode.
Message 5 of 6
antinode
Guru
> [...] The Orbi router has my public IP address as assigned by my ISP
> so I'm assuming [...]
   That's "deducing", not "assuming".  (_Before_ the test was
"assuming".)
   As for the actual problem, a firmware version might be interesting.
> [...] I can't find any information [...]
   Nothing in the router log?  (ADVANCED > Administration > Logs)
> [...] I bought the Orbi in May 2017 so it's getting old, is it just
> failing?
   I wouldn't call four years "old", but many things are possible.
There's a battery of wishful-thinking techniques which seldom cause much
more trouble than wasted time.  For example:
      1. Settings reset, manual reconfiguration.
      2. Firmware reload.  (Followed by 1.)
      3. Firmware load, different version.  (Followed by 1.)
      4. Power adapter, test or swap.
   Also, there are Orbi-specific forums:
      https://community.netgear.com/t5/x/ct-p/home-orbi
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1087 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
