Reply
Netgear R6300 and WD MyBook Live Duo - cannot access dashboard
krivi
Follower
Hi
I connected the two and I cannot access the dashboard, but the folders on my hard drive without a problem. I tried everything I found on Google, setting port forwarding, fixing IP for the My Book Live Duo etc....nothing is working. Maybe somebody here has the same problem and fixed it. Please help me! I have no idea what else to try 😕
Thanks, Rok
Message 1 of 4
whsbuss
Re: Netgear R6300 and WD MyBook Live Duo - cannot access dashboard
I assume you mean the UI? I have the 2TB MBL connected to my R6300 and have no issues. If you mean remote access, you have to setup the MBL with WDC.com
Message 2 of 4
jmizoguchi
Virtuoso
use the qote wisely
http://forum1.netgear.com/showthread.php?t=56317
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 4
Stryker0129
Hi Krivi, I'm just curious if the recommendation of whsbuss did resolved the problem that you have. Assuming that you are accessing the dashboard using http://mybookliveduo/, I believed this will not work since you set up 2 WD MyBook Live Duo. If you want to access the dashboard, better to use the IP address assigned to them.
Message 4 of 4
Discussion stats
  • 3 replies
  • 5551 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
