Reply
Highlighted
Netgear WNDR3600 anyway to disable WPS
Sometimes with my laptop or a new device I am asked to go upstairs to my router and press the WPS button otherwise the new device may not connect.
Anyway to disable doing this? Not a big deal but thought I would ask.
Thanks
PC
Message 1 of 7
Highlighted
Virtuoso
Re: Netgear WNDR3600 anyway to disable WPS
WPS is an option to use and you should able to use encryption ex.WPA2 to connect
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 7
Highlighted
Re: Netgear WNDR3700 anyway to disable WPS
Correction it is a 3700 Netgear model
I have been using WPA2-PSK
It is just a nit, I Can press the button.
Just wondered if there was a way to disable it.
Thanks
Peter
Message 3 of 7
Highlighted
Virtuoso
If you are using WPA2 then there is no reason to press button on router.Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 7
Highlighted
Retired_Member
Not applicable
Disable routers Pin under wireless settings, I think is what you are looking for.
Message 5 of 7
Highlighted
Apprentice
From a brief look at the PDF manual, it doesn't appear to have a way that you can disable the WPS feature.
If it is a serious concern, or you need more clarification, or you need a definite answer to your query, I would suggest you open a case by logging in to my.netgear.com.
Message 6 of 7
Highlighted
Virtuoso
if you are able to disable WPS you will see same or not
http://interface.netgear-forum.com/WNR3500/
"Advanced"- Wireless settings. you will see WPS settings, disable router's PIN
if you do not see this option then answer is NO.. you can not disable it.
possible telnet and do more advance tweaking
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 6017 views
  • 0 kudos
  • 4 in conversation
Announcements
