Reply
Highlighted
Follower
Netgear WNDR3700v4 Firmware 1.0.2.78
Hello
After I made the upgrade to Firmware 1.0.2.78 I have the Problem that i need to be really fast to enter the Menu shown in the screenshot. After I click on wireless configuration the button is only one second visible and disappears. Is it possible to make the button visible again?
Thanks for your Help
Message 1 of 2
Highlighted
NETGEAR Employee Retired
Re: Netgear WNDR3700v4 Firmware 1.0.2.78
Hello @Tutanchamun,
Welcome to the community!
It should still be available even after upgrade. Since you mentioned that it disappears, you may need to reset the router by pushing the reset button for 10 seconds. Once you have reset, you have to configure the router and do a fresh start. Let us know what happens.
ElaineM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2587 views
  • 0 kudos
  • 2 in conversation
Announcements
