Reply
Netgear WNDR4700 weird connection issues
bryan9915
Follower
I have a WNDR4700 I just got back from a long weekend and the router is acting strange. I have several devices connected to it with different out comes.
Win 10 HTPC - no connection issues
Xbox 360 ethernet - no issues
Xbox over Wifi - will connect but not reach the internet
Wink Hub - no issues
GS3 - will connect but no Internet
Droid Turbo - will connect but no Internet
Win 10 laptop. - will connect but "limited". network center say unidentified network. When I connect it via ethernet it will fully connect but after a while it dropped to a unidentified network.
I have done multiple restarts on both the router and devices. I also did a factory reset on the router but no luck.
Thanks for the help in advance.
Message 1 of 2
Babylon5
NETGEAR Employee Retired
Re: Netgear WNDR4700 weird connection issues
Are there any hints as to what might be happening in the router log? For those devices that show a connection to the network but not the Internet, what does their IP data show? If you power off / disconnect all devices, then just attempt to connect one problem device what happens?
____________________________
Working on behalf of Netgear
My name is Andy
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2712 views
  • 0 kudos
  • 2 in conversation
Announcements
