Reply
Netgear WNR2000v2 - Cannot login
Chearful
Hello, I currently have a WNR2000v2 router. I need to port forward something to my PC but I cannot seem to authenticate in.
You can see this in the GIF: https://gyazo.com/66de7a3d46eb225173f79ab4feaea325
I have verified that the password is correct, and I performed a factory reset on it (by poking a pencil in the reset button) but with no luck.
There are no errors, but it is literally putting me through a login loop which is rather frustrating.
Any help would be great - thanks.
Message 1 of 5
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Netgear WNR2000v2 - Cannot login
Perhaps the router is not fully resetting itself.
Try to use a paper clip. If the same thing happens, it could be a hardware problem.
By the way, did you try to use a different computer and a browser?
ElaineM
NETGEAR Community Team
Message 2 of 5
All Replies
ElaineM
ElaineM
Message 2 of 5
Chearful
I have tried it on Chrome and Internet Explorer on my main PC and laptop without any luck.
I will attempt to fully reset my router again but with a paper clip.
Message 3 of 5
Chearful
It works, thank you for your help!
Message 4 of 5
ElaineM
You're welcome.
Glad to hear that it worked!
ElaineM
Message 5 of 5
Discussion stats
  • 4 replies
  • 2544 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
