Reply
Netgear WiFi Extenders Affected by end of 2G service?
lmendolyahoocom
Follower
I have two Netgear WiFi Extenders, one of which is a EX 3700 Model.  I am wondering if these extenders will be afected by the nationwide 2G system being stopped at the end of February.  I have questions on both.   specifically if there will be affected by the turning-offf of 2G networks.
1) The EX 3700 was purchased and installed in 2020, and is capable of working on both  2G and 5G signal bands.  When I first installed it, I set it up on the 5G band, but was having low signal strength and problems in even getting it to work.  Netgear's tech support told me, at that time, that I should set up in 2G since the 5G network was for closer signals and the unit was in another room.  I am wondering if this will stop working in March, AND if I need to now try to set it up in 5G mode.
2) The other etgear WiFI extender is an older model, and I do not believe it is a 2G/5G unit.  Will I need to replace this with one that will work on a 5G network?
Message 1 of 2
Guru
Re: Netgear WiFi Extenders Affected by end of 2G service?
The nationwide is 2g cellular.
Not wifi.
Your devices will work fine.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 355 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
