Discussion stats
  • 1 reply
  • 226 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Netgear router C3000 as second router with Verizon ActionTec
Hi, I'd like to ask for some help setting up my Netgear C3000 router as a second router, so i can use it as a visible network for my windows 10 laptop or other guests who visit me.
My Current network does not broadcast (its hidden) and i connect it by creating hidden network option in my devices.
Unfortunately windows 10 laptop keeps disconnecting with hidden connection.
 I tried to setup C3000 router by manually connecting to primary router via ethernet, C3000 showed up as  a new network, but
internet connection is not available when i use Netgear C3000 network. i tried connection windows 10 laptop wirelessly to Netgear C3000. (no internet) When Laptop connected (wirelessly) to Verizon ActionTec internet is fine.
I'm probably doing something wrong .
btw (the Access point option shows only readonly wireless network names ) someone from another thread( 2years before) told C3000 does not support wireless Access point option but manual ethernet must work.
Model: C3000|N300 Cable Gateway Docsis 3.0
Message 1 of 2
Highlighted
Sensei
Re: Netgear router C3000 as second router with Verizon ActionTec
> [...] setting up my Netgear C3000 router as a second router, [...]
   As a second _router_, I doubt that it's possible.  As a wireless
access point, you might have a chance.
> via ethernet, [...]
   What, exactly, did you connect to what, exactly?  What, exactly, is
your "primary router"?
> names ) [...]
   Are you talking about ADVANCED > Administration > Wireless AP?
That's strictly information about _other_ local WAPs.
> [...] someone from another thread( 2years before) [...]
   Thanks for the helpful link.
> [...] told C3000 does not support wireless Access point option but
   The C3000 lacks a convenient WAP option, but that doesn't make it
impossible to use it that way.  You might try the procedure at:
      https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a C6300-as-WAP, but the steps are about the same for
any other router (any make/model) which lacks a one-step WAP option.
   The cabling for that scheme may be what you have tried, but there are
more details to handle than just connecting the cable.
Message 2 of 2
