Discussion stats
  • 34 replies
  • 16374 views
  • 0 kudos
  • 12 in conversation
Announcements
Top Contributors
Reply
Highlighted
Novice
Netgear wnr1000v3 issues...
I just upgraded the firmware to v2>v3 not long ago and now the signal or connection keeps dropping every hour or so and then it dissconects me and won't be able to re-connect back unless to power off the router nd on, it happens
Than if I go wired it works perfectly but wireless it's terrible everywhere.
Message 1 of 35
Highlighted
Virtuoso
Re: Netgear wnr1000v3 issues...
HARD RESET the router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 35
Highlighted
Novice
I did that twice nd no luck pressing the little button for 30s and yeah... It seems the routers rubbish And Btw I upgraded the firmware thru my iPhone for some reason
Message 3 of 35
Highlighted
Virtuoso
there is now such thing as 30sec for reset
see router reset on my sig below for all the correct options for resetting
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 35
Highlighted
Novice
Isn't a hard reset is when your settings go back to default? Yea I did that twice
Message 5 of 35
Highlighted
Novice
It's getting really annoying I followed step 2 it set my router to default but now it's still the same man
Message 6 of 35
Highlighted
Virtuoso
if you still have drop issues then I would now look into channel interference issues
http://www.metageek.net/products/inssider/
survey the surrounding and use any of channel 1,6,11 if you are in US. 13 will be for europe
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 35
Highlighted
Novice
Nah I'm from Australia ?
Message 8 of 35
Highlighted
Virtuoso
1,6,11 .........
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 35
Highlighted
Novice
jmizoguchi wrote:
1,6,11 .........
Yeah i put it to 6 and I see no change
Message 10 of 35
Highlighted
Virtuoso
If chan6 is clear with other wirerless around you then revert the firmware, hard reset and see it helps unless it was same issues before you flashed latest firmware
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 11 of 35
Highlighted
Novice
How do I revert back? I think the old firmware had no problems And it's not that clear it drops signal, it doesn't hold on for long
Message 12 of 35
Highlighted
Virtuoso
Go to support.netgear.com and find firmware
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 13 of 35
Highlighted
Novice
hey i downloaded the WNR1000v2-V1.1.2.50.img but it wont let me open it, when i try to open it thru the routers web page it gives me this error "Please assign the correct file. The file format is *.chk"
Message 14 of 35
Highlighted
Virtuoso
You do NOT open *.img fine or even ANY firmware
Makes sure you are downloading wnr1000V3 ONLY
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 15 of 35
Highlighted
Novice
but it didnt have a v3 firmware there ? http://support.netgear.com/app/products/model/a_id/12167
Message 16 of 35
Highlighted
Virtuoso
Huh?
http://support.netgear.com/app/products/model/a_id/12591
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 17 of 35
Highlighted
Novice
jmizoguchi wrote:
Huh?
ok ok, but WNR1000v3 Firmware Version 1.0.2.42 is the firmware im on right now, how am i suppose to go back a firmware
Message 18 of 35
Highlighted
Virtuoso
Go to download tab
Click on check to see any prior list of firmware
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 19 of 35
Highlighted
Novice
jmizoguchi wrote:
Go to download tab
yes i have downloaded all the v3 firmwares even the old ones but when i upload WNR1000v3-V1.0.2.26_51.0.59.chk (before the new one)it just shows a blank with no loading or anything i waited 10 mins and nothing happend
Message 20 of 35
Highlighted
Novice
jmizoguchi wrote:
Go to download tab
sorry i got it to load up on safari think firefox had a problem
Message 21 of 35
Highlighted
Virtuoso
Downloads
WNR1000v3 Firmware Version 1.0.2.26
WNR1000v3 Firmware Version 1.0.2.18
WNR1000v3 Firmware Version 1.0.2.4_39.0.39 (for users outside North America)
Show All Versions
any of these should work and ONLY to use wired to the PC and IE browser.
make sure any third party firewall is disabled on PC
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 22 of 35
Highlighted
Apprentice
Not sure what you did but you can't use V2 firmware on a V3 version. What is the original model number V2 or V3? What firmware was it on and what firmware did you try to upgrade too?
Message 23 of 35
Highlighted
Novice
I am having the SAME issues, its not funny, every hour for the past 3 weeks I have been having to reset my router and as of last night I literally have to unplug my modem and my router and even after that it takes a while to get back on line. I am about to take this back and go back to Linksys.:mad:
Message 24 of 35
Highlighted
Novice
There would seem to be a major problem with the new firmware in some cases - I have also had major issues with the router disconnecting and locking up - however reverting to the previous firmware provides a cure - back to previous version and all is fine again.
Does anyone from Netgear read these forums? The new firmware looks very pretty but for some proportion of the customer base it really doesn't work!:mad:
Message 25 of 35
