× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Network Connectivity
oldbadger14
I recently rebuilt my PC and now when I use File Explorer the netgear box shows up as Storage, but I can't reach it.  It use to show up under Network (but in File Explorer it was under the label Compter).
I have no clue why this is happening and I was hoping this forum could lend a hand.
Many thanks,
BLP
Model: RNDP400U|ReadyNAS Ultra 4 Plus Chassis only
Message 1 of 3
antinode
Guru
Re: Network Connectivity
> I recently rebuilt my PC [...]
   Does that mean a fresh Windows installation?  Did you declare the
(new) network connection to be Private?  Windows (Firewall) normally
blocks file-sharing over a Public network connection.
      https://community.netgear.com/t5/x/ct-p/readynas
Message 2 of 3
oldbadger14
Yes, I formatted the drive and put a new fresh version of the OS on my c-drive.  Yes, I did check the network sharing options and I did check mark private.
Thanks for asking - any thoughts?
BLP
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 729 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
