Discussion stats
  • 43 replies
  • 25877 views
  • 1 kudo
  • 8 in conversation
Announcements
Top Contributors
Reply
Highlighted
Re: Network Map Issue on Mobile Device
I loaded the firmware update from the dropbox link provided and it works great
Message 26 of 44
Highlighted
Yes, this also took care of my issue in the Attached Devices menu where it used to show multiple entries with different IP addresses for the same exact devices with the same exact MAC address. I thought someone was on my network spoofing their MAC address to gain access to the router, but it turns out it was just bad firmware. It even showed an iPhone connected trough an ethernet connection. That's some trippy stuff, I'm glad this firmware update fixed all the issues.
Message 27 of 44
Highlighted
On my desktop computer, its connected to the router via a LAN cable. In order for the desktop genie app to show the connected devices, it has to be connected to the wireless network as well. This doesn't seem right. Any suggestions?
Message 28 of 44
Highlighted
I didn't know there is a "desktop" version of the genie app. Can you link me to it? I'd like to check it out myself. I will post back how it works with the latest firmware.
Message 29 of 44
Highlighted
Here is the link to all the apps. Just click on the one for PC or Mac.
http://cl.netgear.com/landing/genie/default.aspx
For mine to work, I have to be connected via WiFi, which then shows both my lan and wifi connections.
Message 30 of 44
Highlighted
Virtuoso
Please check one forum post. It might help you.
http://forum1.netgear.com/showthread.php?p=481063#post481063
Message 31 of 44
Highlighted
that solution worked..
Thanks
Message 32 of 44
Highlighted
Apprentice
Is Netgear going to ever fix this issue with the Network Map not working on the iPhone Genie App?
Message 33 of 44
Highlighted
NETGEAR Employee Retired
@uptownvideo What's the version of your Genie App? Also, what's the model number of your router?
The Network Map shows accurately on my app.
ElaineM
NETGEAR Community Team
Message 34 of 44
Highlighted
Apprentice
Genie App is 2.4.18
Router is a Cable Modem Gateway C6300
Message 35 of 44
Highlighted
I have the same version.
Have you tried uninstalling and reinstalling it?
After uninstalling, restart the iPhone and reinstall it.
ElaineM
Message 36 of 44
Highlighted
Apprentice
I did try uninstalling the app and reinstalling it. Do you have the same router, the C6300?
Message 37 of 44
Highlighted
I'm using a different router.
By the way, what's the firmware version of your C6300?
Who's your ISP?
For verification, here's a list of updated firmware for different ISP's.
Will replicate this from our end and let you know the result.
ElaineM
Message 38 of 44
Highlighted
Apprentice
Router firmware is V1.02.20
Message 39 of 44
Highlighted
Who is your ISP?
Is that really .20 or .21?
ElaineM
Message 40 of 44
Highlighted
Apprentice
COX. It is 1.02.20
Message 41 of 44
Highlighted
Kindly check your inbox.
ElaineM
Message 42 of 44
Highlighted
Apprentice
Is there any fix yet on this issue? It has been almost a year now and now fix.
Message 43 of 44
Highlighted
Based from the case notes our engineering team is investigating this.
ElaineM
Message 44 of 44
