Reply
New Firmware Posted: WNDR3700/WNDR37AV Firmware Version 1.0.14.98
neil0311
Re: New Firmware Posted: WNDR3700/WNDR37AV Firmware Version 1.0.14.98
Simon0 wrote:
The major features are: Support “AP mode” and “Auto IP” in AP mode & Support DFS channel in Australia, Canada, and Europe. Perhaps Support “Port Forwarding Enhancement” may be important for some but I use a separate much more reliable router which alot of other people do already. If only the DFS channels were also available in the US also..
So I'm gathering that if I use it as a router and wireless AP, and don't use port forwarding, that there are few if any concrete benefits to the new firmware?
Message 76 of 195
Simon0
Novice
In AP Mode w/ Auto IP you should be able to use all 5 ports plus time server access. Hence you get a wireless 5-port switch, w/ limited usb NAS support.
Yeah, you won't get much concrete benefits, but surely they've upgraded/fixed parts of its OpenWRT core, so in theory it should be more reliable.. though, may not necessarily always be true :rolleyes:
Message 77 of 195
orion7144
Novice
Why do some devices show "unknown" instead of the name?
Message 78 of 195
J_Hutt
I have been using an XBOX 360 to play video content from my ReadyNAS streaming via DLNA over wired connection. No issues with 7.98.
Wiped all settings, flashed 14.98, ReadyNAS cant be seen. Everything else seemed ok (populated Attached Devices table, finally).
Wiped all settings, flashed back to 7.98, all ok, ReadyNAS visible again. :confused:
Message 79 of 195
therat
neil0311 wrote:
Maybe I'm in a minority, but I have never had any problem with the attached devices list or reservations. Both have worked correctly for me.
Well I suffered from the blank attached devices with 1.0.7.98 but it works perfectly with 1.0.14.98
Message 80 of 195
StaticFree
Tutor
Hi, I have two Netgear ReadyNAS Duo and ReadyNAS 4000 units and they are recognized and working fine with both firmwares 1.0.7.98NA and 1.0.14.98NA. Perhaps it may be a network config setting on your ReadyNAS? I have nothing fancy nor special configured in my ReadyNAS that I can recall. I did nothing special to get them recognized. They are automatically recognized and show up with both firmwares. So please check your configs, reboot the router and see if your ReadyNAS shows up. I do have hard assigned ipaddresses to my ReadyNAS' also. They show up fine.
Message 81 of 195
J_Hutt
By 'recognised', do you mean by the XBOX? I could see my Duo fine on the network with 14.98, as with 7.98. The issue was the XBOX picking up the DLNA service when using 14.98. Not sure what I could change on the Duo to affect it - I did try restarting the DLNA service, rebooted everthing that was or ever had been connected to the network...and tried going back to 7.98 (success) and then back to 14.98 (no-go)
It feels like its a router setting...I use an allocated IP address for the Duo - as I say, the Win7 and Mac computers on the network could see it ok.
Message 82 of 195
mastershake
okay i have a updated firmware now as a beta so the newer one should be up very soon im sorry i can not provide more but so far so good with this next release a few kinks but much better than .14 was imo
Systems repair, network specialist and Netgear reseller / beta tester.
"Some days your the windshield. Some days your the bug"
Frylock: You know what tonight is?
Carl: Yeah the night I'm downloading porn at 14 kilobytes a second!
Carl: Ha! I'm just kidding. I got a netgear 4000 back here.
Message 83 of 195
Simon0
Novice
Just curious, is the beta a firmware rollback based on .7.98 OR will it still have ALL the few features which was added to .14.98?? thanks..
Message 84 of 195
Darkev
I'm not using the USB at all in this router so I cannot speak for that or any of its features. I am using port forwarding and it's working like a charm. The version 1.0.14.98 works wonderful as my router has been going steady for a week now with no reboots. Just this weekend I've installed it on the remote router. So we shall see tomorrow if there are issues with this router when 2 of them connect together using 1.0.14.98. I doubt there will be, but I have to test it anyhow. I'll let you know.
Message 85 of 195
Retired_Member
Not applicable
I just setup a Synolog NAS and Dune media player and have my 3700 connected to a LinkSys WET610N located in my stereo cabinet.
I have not had much success with Blu-Ray streaming. I first had to disable Enable Video Network in the 5GHz settings which removed most video stuttering. I still get the occasional audio drop.
Has anyone else had this issue and does the 14.98 solve this?
A 50' CAT 5E ethernet cable connected between the two works perfectly.
Message 86 of 195
Darkev
So far, both router using firmware 1.0.14.98 are working quite well connected together using port forwarding.
Message 87 of 195
Urdypooh
What happened?
The latest firmware posted here http://support.netgear.com/app/products/model/a_id/11640 is 1.0.7.98 and not 1.0.14.98 anymore.
Message 88 of 195
Wolf_666
Luminary
Urdypooh wrote:
What happened?
Try via ftp: ftp://downloads.netgear.com/files/WNDR3700-V1.0.14.98.img
- Modem Draytek Vigor 160
- Router Netgear RAX200 (Stock FW)
- NAS Synology DS1621+
Message 89 of 195
Simon0
Novice
For those who can't find the LATEST firmwares for the WNDR3700v1 and WNDR37AVv1, here's where to get both the North American and Outside North American versions of 1.0.14.98:
(For North America users only)
ftp://downloads.netgear.com/files/WNDR3700-V1.0.14.98NA.img
File: WNDR3700-V1.0.14.98NA.img
CRC-32: 745300e1
MD4: fceca2375df90571cee72ab6767ad7d4
MD5: 406c566fedd500aaa3f779f549490df1
SHA-1: 2c9de1790d7b4e1fee862afc33e69cf1024e8c4f
(For users outside North America)
File: WNDR3700-V1.0.14.98.img
CRC-32: da57519e
MD4: 69c550ecceeb4873742439af7121de86
MD5: e4d44388122c64035a0c154793f54319
SHA-1: c3ee1c2b255e661ba8722419a4170c658691106e
I've included file checksums for verification purposes, in case you downloaded the firmware from "unreliable/google" sources.:D:D
Message 90 of 195
Darkev
It's odd that the routers don't auto select 1.0.14.98 when you check for an update. I've read some issues with media devices being connected. I don't have anything plugged in to the USB on mine. Are there any major issues with this 14.98 firmware?
Message 91 of 195
Mars Mug
Virtuoso
I believe that version has been removed from the servers, and I might de-sticky this thread if the next version doesn’t appear soon.
Message 92 of 195
fernandn
Message 93 of 195
nToxik
Simon0 wrote:
The most reliable method that I've used is simply put router in recovery mode and then reflash, it has given me the cleanest flash in the past when dealing with Atheros-based routers. WebUI based flashing--I've bricked my router many times & sometimes got a partial flash when I verified the size via the booloader console or checkummed it. On some routers, tftp is the ONLY way to flash.
Do you have the step-by-step instructions on how to do this?
Message 94 of 195
Simon0
Novice
The instructions are at the dd-wrt and openwrt site. You can try these:
http://wiki.openwrt.org/toh/netgear/wndr3700#uh.oh.i.bricked.my.router.optional
Message 95 of 195
nToxik
How do you flash via TFTP?
Message 96 of 195
Simon0
Novice
tftp was installed by default but vista & 7 no longer install it by default for security reasons. Linksys use to make a version of it available for free on its ftp site. I believe WinAgent makes one, and tftd32/64 is a daemon but it also includes a client as well. Also make sure you tell the windows firewall add the client & remove it from the firewall after you've finished using it. I've used the WinXP tftp client & PumpKIN for many years simply because they work and was free. I use the command line version mostly but the GUI versions are VERY nice as well. Perhaps others can give you advice on this matter.
Message 97 of 195
Simon0
Novice
I forgot to mention that TFTP DOES NOT VERIFY that you are flashing the CORRECT firmware before proceeding like what most WebGUI flashing do. You can easily DESTROY the bootloader which will require JTAG to recover because although TFTP will write it correctly to flash according to the layout specified, the "incorrect" firmware when booted may perform writes in areas that it is NOT suppose to. So, be VERY careful and double check the firmware before proceeding.
Message 98 of 195
howardagoldberg
So, here is my story ...
Upgraded firmware to 1.0.14.98 when it came out, and before it was taken down. Everything seemed fine.
My broadband connection (via TWC) is 30 down and 5 up.
The other day, I noticed my two computers that are hooked up to the router via Gigabit Ethernet were only pulling 15x5. Called TWC and argued with them for awhile, but long story short, finally just reset both the modem and the router. This, after discovering that while my wired connections were only getting 15x5, my WiFi (on 2.4) on another desktop and two laptops were getting 30x5! This was Sunday ...
Reseting the router got my speeds back to where they should have been, and all was fine until today. I tested the wired systems against speedtest.net, and was getting 25x5. Not that big a deal, but I was suspicious. Sure enough, I tested one laptop on Wifi and ... 30x5.
Reset the router, and wired connections are golden again.
I am actually not using any of the really "advanced" features at the moment (no AP mode, no IPv6, no bridging, etc.), so this is really a mystery to me. I understand why the wifi connections won't always get 30x5, but the wired?!
Any thoughts are appreciated.
Message 99 of 195
Simon0
Novice
You should first call TWC and apologize to the minimum wage support staff :rolleyes::rolleyes:
The firmware was pulled because they various found serious issues with it.
Reset & flash-back to previous for now....
Message 100 of 195
Announcements
Orbi WiFi 6E
