× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Newbee question about adding mesh to Spectrum
danstanick
Follower
I have a stupid question, but I'm pretty unsavvy about all this tech stuff.  I'm going to replace my Spectrum Router with the Orbi AC 2200.  I have about 30 devices that work with the Wifi.  Will I have to reconfigure all these with the new Router?  Thanks for any help.
Model: AC2400|Nighthawk AC2400 Smart WiFi Router
Message 1 of 2
Guru
Re: Newbee question about adding mesh to Spectrum
If you use the same ssid/password that the old router used, they should auto-connect.
I switch routers all the time and use this method. I haven't found 1 device yet that wouldn't auto-connect (provided the ssid/password are the same)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 452 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
