- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AC1750 (R6400)
- Mark as New
- Bookmark
- Subscribe
- Permalink
What started my day off was my internet abruptly stopped. I switched out a couple of cables, still nothing.
I went through the whole deal of resetting the modem, router, pc. More of the same.
I then contacted an ethernet cable from router to pc. That was working, just no wifi.
I checked my WiFi networks, the 2 that I once had were missing.
I explained all this to support. He told me my network was no longer private. He also said I needed to buy Netgear Security to get it up and running. I said I dont want it. Then he said I'm out of luck. My only way was to get security (i asked if I could use another firewall, he said no.
Then he hung up on me. I called again, the same guy answered. Then he said, to make my network private that he had to search and delete all the IP addresses that were on my pc, phone. Mind you, not for free. Basically, my only option was to pay to get rid of IP's, and pay for Network Security.
I'm just flabbergasted. Who talks to customers this way, not to mention the attitude and hanging up on me?
This is the last time I purchase ANY Netgear products. UNBELIEVABLE.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I pressed one of those lit lights on the right side of the night hawk, everything's back to normal now. My cat walks behind my TV all the time, he might have pressed the button. Thanks!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AC1750 (R6400)
1. Netgear doesn't sell you firewalls. IF some guys was trying, you didn't contact netgear support. Most people who "contact support" google for a phone number and get scam/con sites. To get a hold of support. Click on "MyNetgear" at the top. Register an account (or login) and then the device. From there you can start the support process. Keep in mind that its only free for the first 90 days. After that it does cost but they aren't selling you a firewall.
2. If you're wanting help from the community, we needed better details and more details. Like:
- modem/gateway its connected to
- firmware on the router
- a better description of the problem. what are the led's on the router doing, do wired devices have issues, was it factory reset and just needs to be reinstalled, etc. the more details you tell us, the better we can help.
3. Sometimes the fastest/easiest route is to just factory reset and start back at stock. Have you tried this?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There's the clue. There is a very high probability that you were not talking to Netgear.
Let me guess, you did a search on something like "Netgear support". Then you called the number that you found.
If that is the case, you probably hit one of the various scam merchants out there who have nothing to do with Netgear.
If you can provide details of the number you called, or the website you found, we can tip off Netgear so that it can throw its lawyers at these crooks.
I hope you didn't allow these people anywhere near your network. If you did, then run as many security scans as possible.
If you still have problems, and you pare out of the 90-days free setup support, try this place.
Netgear does not actually run a support service. It handles that through GearHead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can come here though, sounds like the wifi either went out on your router or someone accidently pressed the button on the right for the wifi. I think its the 2nd button to the left. you have to press it for 2 to 3 seconds if that's what it is. If not I'd reccommend you to do a hard reset of your router by pressing the reset button with a paper clip for 30 seconds which will bring it back to default settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
