Reply
No Ethernet Cable Is Plugged into the Router Internet Port
susakma
Follower
I am using a DGN2200v4 modem router with an ADSL connection. I have updated to latest firmware V1.0.0.66. When i go through the setup wizard I get a message saying "No Ethernet Cable Is Plugged into the Router Internet Port". That would be port 4 reserved if I am using a fibre modem but I am not. I have the phone line plugged directly into the wall. I have tried changing the settings so port 4 is only used for LAN, tried hard reset nothing works.
Suggestions?
Message 1 of 2
TheEther
Guru
Re: No Ethernet Cable Is Plugged into the Router Internet Port
Try setting the WAN Preference to Must use DSL WAN and Use port 4 to LAN port.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4514 views
  • 0 kudos
  • 2 in conversation
Announcements
