- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No Internet on Firestick w EX6120 or 7300
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is a strange problem. Firestick connects OK with Internet on Router 2.4 or 5.0
Have 2 NetGear Extenders, EX6120 and EX7300. Firestick connects to network but will not connect with Internet through either of the Extenders. Many other devices, including a Fire TV, will connect with Internet through either extender. Firestick shows very strong signal strength for both extenders. Have tried various extender configurations and restarting Firestick and Network with no success.
Suggestions will be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No Internet on Firestick w EX6120 or 7300
What modem do you have?
What router are they connecting to?
Did you setup the extenders using wps or using the installation assistant?
Are you using any special characters/spaces in your ssid/password? (if so, remove them)
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:What modem do you have? Verizon FIOS G-1100 Gateway
What router are they connecting to? Verizon FIOS G-1100 Gateway
Did you setup the extenders using wps or using the installation assistant? WPS
Are you using any special characters/spaces in your ssid/password? (if so, remove them) No
Firestick connects OK directly to Gateway. PWs for Extender Nets are same as Gateway Nets. Here is example T3Batsarecrazy250
Other suggestions?
Thanks much
Tom
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try setting the extenders up using the installation assistsant? I'd give that a shot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:Did you try setting the extenders up using the installation assistsant? I'd give that a shot.
Not going to go through assstant at this point. I may have used it though because I set the extenders to static IP. Do you think it could have anyting to do with me assiging static IPs to the extenders?
I am ordering a 2cnd Firestick for another TV in next few weeks. When it comes in I will see if it will connct through Extenders. I will take it from there.
Thanks for your help
