Reply
No internet on WNR2000
bumblebee
hello all,
I have lost internet on my WNR2000 (1.2.3.7 firmware). I'm using Time Warner Cable Roadrunner. I'm also running Windows 7. If I bypass the router I have internet. Any ideas? Please help!!
Message 1 of 11
jmizoguchi
Virtuoso
Re: No internet on WNR2000
1. turn off the cable modem and unplug ethernet cable
2. wait for few min (20min)
3. turn on the cable modem only and do NOT plug any ethernet cable
4. wait until all the light up on cable modem
5. ONLY after all the light is up. hook up a router behind the cable modem
6. you should able to get public IP from the ISP and it will show up in the router status when you login the router.
** remove the BATTERY from the cable modem if built-in and follow from #1~
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 11
bumblebee
router status says the IP is 0.
Message 3 of 11
rsg
If you are getting ip as 0.0.0.0
try these steps
just connect router and pc and
power onn the router and and reset it first, power off and on , wait for some time
try to login on to router page, and reconfigure it
check the ip also as what it is getting.
else
start
win+r
cmd
ipconfig/release
ipconfig/renew
power off router
power on the router
connect modem
and try
you will get ip
thanks
Message 4 of 11
jmizoguchi
Virtuoso
which cable modem model you have..?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 11
bumblebee
Cisco 2100
Message 6 of 11
bumblebee
try these steps
else
start
win+r
cmd
ipconfig/release
ipconfig/renew
power off router
power on the router
connect modem
and try
you will get ip
thanks
still no IP:confused:
Message 7 of 11
jmizoguchi
Virtuoso
bumblebee wrote:
Cisco 2100
is this you have ?
http://www.cisco.com/en/US/products/ps7206/index.html
if not put the URL relates to the model you actually have
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 11
bumblebee
jmizoguchi wrote:
is this you have ?
yeah, I'm pretty sure this is the model. Cisco 2100 cable modem.
Message 9 of 11
jmizoguchi
Virtuoso
Post the URL to the products like I asked
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 11
bumblebee
http://www.cisco.com/web/consumer/support/modem_DPC2100.html
Message 11 of 11
Discussion stats
  • 10 replies
  • 4420 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
