× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Orbi RBR40 Firmware Update
lyrussel
Initiate
I got an email this morning saying that a new firmware update is available - Latest firmware version: v2.3.5.34.  I logged on to my Orbi and it says it is running V2.3.5.30.  So I click on check button and it says "No new firmware version available."
Any ideas how I can upgrade to the latest?
Message 1 of 4
Accepted Solutions
lyrussel
Initiate
Re: Orbi RBR40 Firmware Update
Perfect - thank you!
Message 4 of 4
All Replies
geobehr
Same here, RBR20 current at .26, email says .36 available, both web login and app say 'no new firmware updates'
Message 2 of 4
antinode
Guru
   Or almost any other...
   Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.
   "Beta" or "Hot Fix" versions typically will not be applied by the
automatic update scheme.
Message 3 of 4
lyrussel
Initiate
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2986 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
