Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi pro behind UDM router | Dynamic Vlan via radius
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-16
05:25 AM
2021-10-16
05:25 AM
Dear community, dear netgear,
Team,
I set up a UniFi UDM as a router with a radius server. Behind the UDM, I am running a Orbi Pro on firmware 3.3.0.122 as an AP. The challenge is that I would like to dynamically assign a vlan to Orbi clients based on the radius authentication on the UDM.
For now, the authentication works, but the ips assigned to clients do not match the correct vlan address range, even though the tcpdump on the UDM indicates the right vlan in the accept message. so it seems the Orbi pro just doesn’t “understand” / “convert” / “translate” the radius reply correctly to its clients.
I found some documentation on dynamic vlan for other netgear products but non of it for the Orbi Pro. The configurations mentioned for other products (dynamic vlan, …) are not available in the Orbi pro Settings, so I cannot select anything but the radius ip, port and shared key. If I select a vlan, only the selected address range is used, even if the radius credentials and the tcpdump would suggest a different address range.
How can I configure the Orbi Pro to dynamically select a vlan?
Thanks
Team,
Thanks
Model: SRK60B06|Orbi Pro Tri-Band Business WiFi System
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-16
10:35 AM
2021-10-16
10:35 AM
Re: Orbi pro behind UDM router | Dynamic Vlan via radius
Netgear has set up a community forum specifically for the Orbi Pro (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi Pro and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-16
10:37 AM
2021-10-16
10:37 AM
Betreff: Orbi pro behind UDM router | Dynamic Vlan via radius
Addition: The Orbi Pro is a SXK80 and a SXS80
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-16
10:40 AM
2021-10-16
10:40 AM
You'll find more help and support information in that forum
Good Luck.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-16
10:44 AM
2021-10-16
10:44 AM
OK, thank you. I posted it in the other forum.
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-16
10:49 AM
Announcements
