× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
PLEASE HELP
dotelvis
PLEASE HELP
Why does my router update then tell me it has FAILED? Then it reads 403 error; page not available.
ROUTER MODEL: WNR2000v5
Thanks for any help you can give me; otherwise, Netgear will charge me $89.90 to help me!
Message 1 of 22
olympos1625
NETGEAR Employee Retired
Re: PLEASE HELP
Hi tddougla,
Good day!
Welcome to NETGEAR Community!
Thank you for reaching out. May we know what are the LED lights on the router( color and behavior)? Do you still see the wifi signal of the router? Please DM us the serial number of the router.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 2 of 22
dotelvis
Re: PLEASE HELP
My router has 3 lights, neon in color and steady with NO blinking. The Serial # is 3U814856084B8.
Thank you for any assistance you offer.
DOT
Message 3 of 22
olympos1625
Re: PLEASE HELP
Hi dotelvis,
Good day!
Thank you for getting back to us. Those LEDs are Power, Internet and WiFi. What are the colors of the LEDs? Please check ths link https://www.downloads.netgear.com/files/GDC/WNR2000V5/WNR2000v5_UM_20Nov2014.pdf
Please wired a computer using ethernet cable then check if you can go online or get an IP address from the router.
Oliver
Community Team
Message 4 of 22
Re: PLEASE HELP
Hard to tell without knowing what you are doing and where it goes wrong.
The best way to update firmware is manually.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
@dotelvis wrote:
...otherwise, Netgear will charge me $89.90 to help me!
Your router dates back to 2014. Netgear provides free support for the first 90 days after purchase.
This place is free.
Message 5 of 22
dotelvis
Re: PLEASE HELP
As previously stated, the lights are NEON in color.
My computer has Ethernet from it to the router.
Message 6 of 22
dotelvis
Re: PLEASE HELP
I have tried to download manually but I get an error message!!
Message 7 of 22
Re: PLEASE HELP
Not a colour I have even come across.
Red, white, green and amber are the colours that Netgear uses. They can also be flashing or steady.
Neon is a technology. Neon lights can come in a rainbow of colours.
Message 8 of 22
dotelvis
Re: PLEASE HELP
Where I live, we call this color Neon........but it is greenish!
Message 9 of 22
dotelvis
Re: PLEASE HELP
Where I live we call this 'greenish' color neon. 🙂
Message 10 of 22
olympos1625
Re: PLEASE HELP
Hi dotelvis,
Thank you for the clarification. Since you have green internet LED it means that you should be able to go online. Do you have internet access? You said that the " router update then tell me it has FAILED?" Did you mean that you are in the process of updating the router and it went successful but somehow telling you it failed or you cannot access a website? Does it affect all your devices connected to the router? What is the current firmware version of your router?
Note: Please try to reset the router.
Oliver
Community Team
Message 11 of 22
dotelvis
Re: PLEASE HELP
Thank you Oliver for your response.
I have Internet access with all my gadgets; no problem.
Yes, It downloads the firmware then tells me it FAILED!
My last version is V1.0.0.74 and I was trying to get the latest one V1.0.0.76 which fails.
Before I pay $89.90 I will purchase a NEW router. I am a Novice swould you suggest what kind of router would work for me?
Thank you!
DOT
Message 12 of 22
dotelvis
Re: PLEASE HELP
Yes Oliver, I have rebooted the router! 🙂
Message 13 of 22
Re: PLEASE HELP
The best way to update firmware is to do it manually. The automated process can't cope with anything out of the ordinary. It can also damage your device if anything falls over in the [rocess. (The Netgear team isn't going to admit to that.)
This is the best option:
I know I have said that before, but no harm in repeating the usual advice. It works for most people.
Don't do that. This place is free. Lots of (mostly) helpful volunteers.
Message 14 of 22
Re: PLEASE HELP
Where do you live?
The science of neon gas – The colour of neon is strictly orange-red
I don't agree with that either.
Message 15 of 22
dotelvis
Re: PLEASE HELP
Your last comment hasn't arrived here yet but I got an email.
As stated previously, I have attempted several times to download manually and all I get is an error message. DELL gets the same error when they attempt it.
Thanks!
Message 16 of 22
Re: PLEASE HELP
What is that error message? When do you get it?
WNR2000v5 Firmware Version 1.0.0.76 | Answer | NETGEAR Support
These things can fail for many reasons with many possible error messages. Knowing exactly what happens is the key to fixing it.
Message 17 of 22
dotelvis
Re: PLEASE HELP
I click to download manually, then I open File and click on DISC Image and it says, "Disc Image is corrupted." I then click on Release Notes
and get "Hmmmmm, can't reach this page."
Message 18 of 22
olympos1625
Re: PLEASE HELP
Hi dotelvis,
Just for clarification, did you follow these steps?
To manually upgrade your router’s firmware:
  1. Connect your computer to your router with an Ethernet cable.
  2. Visit NETGEAR Support.
  3. Enter your router’s Model Number or Product Name.
  4. Click Downloads.
  5. Select a firmware version and click Download.
  6. Unzip the file if needed.
  7. Enter routerlogin.net into a web browser.
    A login page displays
  8. Enter the router admin user name and password.
    The default user name is admin. The password is the one you specified the first time you logged in. The user name and password are case-sensitive.
  9. Select ADVANCED > Administration or Settings > Administration.
  10. Select Firmware Update or Router Update.
    The label varies by router.
  11. Click Choose File or Browse, then locate and select the firmware file that ends in .img or .chk.
  12. Click the Upload button.
Oliver
Community Team
Message 19 of 22
dotelvis
Re: PLEASE HELP
ISSUE RESOLVED! Thanks everyone for your comments!
DELL had me power off and power on my Router then the upgrade process worked perfect! I should always remember to
turn off/on as that usually works with everything! Hooray!
Message 20 of 22
olympos1625
Re: PLEASE HELP
Hi dotelvis,
That's good to hear. We're glad that you're happy with your NETGEAR device! NETGEAR Team.
Have a good day!
Oliver
Community Team
Message 21 of 22
antinode
Guru
Re: PLEASE HELP
> [...] then I open File and click on DISC Image and it says, "Disc
> Image is corrupted." [...]
   Better to follow the instructions, and not rely on your intuition.
      https://community.netgear.com/t5/x/x/m-p/1721037#M124018
   Strictly speaking, neon is an element.
      https://en.wikipedia.org/wiki/Neon
There's a picture there, showing its distinctive "orange-red glow".
   There are some green lines in the neon emission spectrum, but they're
generally drowned out by the more numerous and intense reds and oranges.
   So, whatever you might call "this color Neon", no one else can be
expected to know what you mean.
   In gas-discharge signage, most colors other that that distinctive
orange-red are produced by other gases (argon, mercury vapor) and
phosphor coatings on the glass; neon is not involved.
   For a good (educational) time, get a cheap diffraction grating, and
use it to look at some signs.  The difference between an actual neon
spectrum and what you get from other-color signs is obvious and
striking.  Better hurry, before LEDs drive the educational signs into
oblivion.
Message 22 of 22
Top Contributors
Discussion stats
  • 21 replies
  • 2806 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
