- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Password Reset on AC1600
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to update the firmware on my modems (I have two) and have forgotten my login and password to the modem (C6250/AC1600 WFI Cable Modem Router). I know I have changed the password, but I am not sure about the login name. My other router sent me to a password recall screen, but this router is just kicking me out. How can I do a factory reset on this modem/router?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Forget it. You can't update the firmware on a cable modem. Only the ISP can do that.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Password Reset on AC1600
> I am trying to update the firmware on my modems [...]
> [...] (C6250/AC1600 WFI Cable Modem Router) [...]
How did you propose to do that on a DOCSIS cable modem+router? Is
there some actual problem which you are trying to solve?
> [...] My other router [...]
Same model, or some other (unspecified) device?
> [...] How can I do a factory reset on this modem/router?
Same as on any other Netgear router? What did your Web search find
for terms like, say:
netgear router password reset
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for
"Factory" or "reset"?
First, you might want to look for "firmware".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe I wasn't clear. I wanted to see if I could update my firmware (i know how to do this). I was unable to log into the router and could not remember my password. I was hoping you could help me recover my password or reset the modem. I have figured out how to reset the modem and everything is ok. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Maybe I wasn't clear. [...]
Yup. Still true.
> [...] I was unable to log into the router [...]
What is your "the router"?
> [...] I have figured out how to reset the modem [...]
What is your "the modem"?
> [...] I wanted to see if I could update my firmware (i know how to do
> this). [...]
What is your "my firmware"? Is it related in some way to your
"the router" or your "the modem"?
Perhaps you know what you're doing, but evidence is sparse.
- Mark as New
- Bookmark
- Subscribe
- Permalink
