Reply
Highlighted
Follower
Password issues
Looking for some insight.
I installed the latest firmware to my WNDR4300 and now when I try to logon to the wireless it tells me my password is incorrect.
I went to my router settings and changed the password and still connect connect devices to my wireless.
Any ideas?
Thanks.
Message 1 of 4
Highlighted
Master
Re: Password issues
Hi,
You talking about WiFi passphrase or router log in password? If you are still stuck, do a factory reset and configure the router again and see.
Message 2 of 4
Highlighted
Re: Password issues
Sounds like the wifi password.
I didn't know that firmware updates would affect that.
Does it still show the old SSID? If not, unless you stuck with the original default, then the update must have wiped the settings.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
Highlighted
Virtuoso
Re: Password issues
Try changing the SSID as well aside from the password. If still having the same problem then reset the router to factory default.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 12388 views
  • 0 kudos
  • 4 in conversation
Announcements
