Reply
Port 443 Fowarding on R6300V1
GDFrenk
Am attempting to seup https through my router R6300 V1 ... using LetsEncrypt and IIS (on Windows 10).
Have successfully setup LetsEncrypt which can see and cert my webs.
However, cannot verify that port 443 is being forwarded to IIS.
The Netgear genie only allows forwarding "service http" which set ups "External & Internal" End port 80 ... but does not mention port 443.
And when I attempt to "Add Custom Port" ... it says that is already "in use" ... though i cannot find any other setting that mentions it or uses it.
My question is ... when you select "service http" ... does the 6300 also forward 443 (even though it does not mention it).
Is there some way to verify that the 6300 is in fact fowarding port 443?
Model: R6300|Dual Band 11ac WiFi Router R6300
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: Port 443 Fowarding on R6300V1
Hi @GDFrenk,
Please try disabling UPnP on the router.
Dexter
Community Team
Message 2 of 4
GDFrenk
UPnP is and was disabled ... i.e. the check box "Turn UPnP On" is not and was not checked.
Message 3 of 4
GDFrenk
USB Readyshare
-> USB Storage
-> Advanced Settings
Even though USB Readyshare was not on (disabled)
... the settings used port 443.
Cleared all the settings there ... and bingo ... IT WORKED!
Message 4 of 4
Discussion stats
  • 3 replies
  • 2477 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
