Reply
Port Conflict With other Service
impactonu
Im trying to port forward a mohaa server with the port 6667 and end port 6667 right so when I click TCP/UPD and put in port's and put in 192.168.1.2 as my ip I get this error. Port Conflict with other service. Uhhm what is this please help..?
Message 1 of 11
impactonu
Re: Port Conflict With other Service
* And my router id is : WGT624 v3 NETGEAR WIRLESS
Message 2 of 11
SilentHunter13
I get the same problem with Dawn of War.
I am trying to add my Dawn of war to IP 192.168.1.3 however whenever I fill in the information and press apply I get the same message.
I am trying to forward port 6112
Whats going on?
Message 3 of 11
jmizoguchi
Virtuoso
moving Super-G (108 Mbps) & 802.11g (54 Mbps) Routers
try hard reset and see
visit my site for "router reset" step1
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 4 of 11
knotbeer
Anyone ever fix this? I have reset my router. I even pulled out my old Belkin router and used it for a week with my NETGEAR router unplugged. Still, after a "hard" reset and everything, it still seems to be "hiding" these ports that have previously been forwarded but no longer allows me to see them, let alone remove the setting.
I really need to forward some ports to another IP. My problem is that I had one PC hooked up that had like 5 ports forwarded to it, but now I want to have 2 of them going to another PC but it doesn't work unless I hook up my other router to it and set it up as a switch, but that's extremely cumbersome and annoying.
Please help! I have a WGR614v7 using Firmware ver: V2.0.23_1.0.23NA
Message 5 of 11
lejael
Novice
try disabling the UPnP before adding more ports. enable it after you've added the ports..hope this helps..btw you'll have to assign different service names for services you want to add back..i think its an "issue" with the router firmware...
Message 6 of 11
Mars Mug
Virtuoso
I'm hoping he's found a fix in the 18 months since this thread was last open.
Message 7 of 11
jmizoguchi
Virtuoso
it's usually user to add some thread counts thais is all they are doing Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 11
Mars Mug
Virtuoso
Well he has a way to go to catch you up Smiley Wink
Message 9 of 11
jmizoguchi
Virtuoso
and some user ready to spam advertisement. I start to see cycles too with lately a spam advertisement in EVA area Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 11
florenceit
adding a new service with a different name is what fixed it for me on my wndr3700
and i also turned off upnp first as well, not sure if that helped.
Matt
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 39633 views
  • 0 kudos
  • 7 in conversation
Announcements
Orbi WiFi 6E
