Reply
Port Forwarding 2 ps4
Starblerc
I am trying to port forward the same port for two ps4 on the network. I have an open nat type for one but cannot figure out how to do it for both.
Ac1900
C7000v2
Message 1 of 4
antinode
Guru
Re: Port Forwarding 2 ps4
   You can't forward the same external port to two different internal
destinations.  You'd need to use a different external port number for
the second device.
Message 2 of 4
Starblerc
I am port forwarding for COD black ops4. Which requires certain ports. How do I go about doing this?
Message 3 of 4
antinode
Guru
   Says who?  Are you following some set of instructions?
   I know nothing about this game.  Does it require port forwarding for
ordinary player use, or only if you're running a server?  Are you trying
to run two servers from one site?  That could be tough, unless there's a
way for a client to specify non-default port numbers when making a
conection to the second (...) server.
> [...] How do I go about doing this?
   Start with why, and work up to how?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1621 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
