Reply
Follower
Port Forwarding issue on Netgear D7000v2
Hi all, I am Online trainer providing Information Technology training to students through webnair i am facing the following problem, I have a weird problem. From my Netgear D7000v2 router (Firmware: V1.0.0.51_1.0.1) I have been trying to do port forwarding on certain ports. Previously I used to do the same thing from my BT router without any problem (quite experienced with the process). After DynDNS and port forwarding Whatever devices are connected to my Netgear Router (Home Wifi) can not access to the services but I can access those services from the internet (not from my home wifi). Anyone got any clue what I might have done wrong? Or is it a fault with the Router/Firmware? And I am sure it's got nothing to do with Firewall because its working from outside of the local network and I tried turning my server firewall off.
FYI I do not have any intention to flash the router with DDWRT.
Appreciate any help.
Thanks
Message 1 of 2
Guru
Re: Port Forwarding issue on Netgear D7000v2
> [...] D7000v2
   There's a more specific forum for "DSL Modems & Routers", where you
might have been more likely to find relevant information on this
problem than you would in this "General WiFi Routers" forum:
      https://community.netgear.com/t5/x/bd-p/home-dsl-modems-routers
> [...] Whatever devices are connected to my Netgear Router (Home Wifi)
> internet (not from my home wifi). [...]
   "can not"?  Do you get some actual error message when you try?
"access" how, exactly?  Are you trying to use the (public) WAN/Internet
address of the D7000v2 from inside your LAN?
> [...] Or is it a fault with the Router/Firmware? [...]
   Most likely.
      https://community.netgear.com/t5/x/x/m-p/1641577
      https://community.netgear.com/t5/x/x/m-p/1637729
      https://community.netgear.com/t5/x/x/m-p/1608830
      https://community.netgear.com/t5/x/x/m-p/1602626
      https://community.netgear.com/t5/x/x/m-p/1581007
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 325 views
  • 0 kudos
  • 2 in conversation
Announcements
