× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Port Forwarding not working on NETGEAR R6080
I have a NETGEAR R6080 with NETGEAR GENIE V1.0.0.34 and the port forwarding isn't working and I believe it has to do with the internal and external port ranges because I have no idea want to put in the boxes please help
Message 1 of 7
Accepted Solutions
Re: Port Forwarding not working on NETGEAR R6080
Well I’m sorry if I lacked information but I don’t know much about the matter and I’m not scamming according to your reply but good thing I solved it myself without your help since NETGEAR community support isn’t good as I concluded so goodbye
Message 4 of 7
All Replies
frankfinn
If  the port forwarding isn't working  on your router contact battery replacement dubai helped me to get all the detail about this. Netgear is one of the best router so far i have used.
Model: AC1450|Gigabit Smart WiFi router
Message 2 of 7
antinode
Guru
> [...]  the port forwarding isn't working [...]
   "not working" is not a useful problem description.  It does not say
what you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
   Is there some actual problem which you are trying to solve?  What,
exactly, were you hoping would happen when you did whatever you did?
> [...] I believe it has to do with the internal and external port
> ranges because I have no idea want to put in the boxes [...]
   If you don't know which port(s) you want forwarded to where, then
it's not really amazing (to me) that, seemimgly, "port forwarding isn't
working".
> [...] please help
   You first?  What, exactly, are you trying to achieve?
> [...] contact <scam link> [...]
   Probably not the best advice.
Message 3 of 7
Message 4 of 7
TaterSalid
Virtuoso
I have lost count so will start over.
antinode - 1
new member - 0
Congrats antinode on your victory. Smiley Sad
Message 5 of 7
Technically he didn’t win he was no help at all I did it myself nobody else helped
Message 6 of 7
Apologies for the heavy handed and condescending responses – and the spam – you received, some people are like that. Glad you worked it out.
Out of interest, can you tell us what you did to fix it? You have marked this question as Solved. So it will show up in searches when people turn up with the same issue. It would be great of you could share the solution with them.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2819 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi WiFi 7
