Reply
Port Opening on Netgear DG834PN not working dispite trying everything.
Benjamin_Barnes
Pretty much what the title says I've tried to open ports on this modem/router for years and it never ever works. I've followed the portfoward guide and tryed there program and nothing.
What can i try? Can easily give any details needed.
Message 1 of 12
Jack_
Re: Port Opening on Netgear DG834PN not working dispite trying everything.
Benjamin_Barnes wrote:
....... I've tried to open ports on this modem/router for years and it never ever works. I've followed the portfoward guide and tryed there program and nothing.
  • What program needs to open ports? Do you know the exact port numbers and if it is UDP, TCP or UDP/TCP?
  • To see if you doing it right, open an arbitrary port (lets say port 1999 TCP. Then use a port scanner to check if that port is really open. I use often Gibson's Shield UP
Message 2 of 12
Benjamin_Barnes
I have 11 ports "opened" at the moment. For xbox,wii and steam I shall try that link now and report back thanks.
Message 3 of 12
Benjamin_Barnes
No packets are reaching any port scanners. Tried ports i've "opened" in port scanners before they just say there not open. Even though i've done everything in modem that the portforward guide has told me.
Message 4 of 12
jmizoguchi
Virtuoso
what IP the WAN/internet port shows.. just shows first three octet x.x.x.0
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 5 of 12
Benjamin_Barnes
How can I find this information?
Message 6 of 12
jmizoguchi
Virtuoso
Router status
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 12
Benjamin_Barnes
Account Name
Firmware Version V1.03.39
ADSL Port
MAC Address 00:1E:2A:23:3D:BF
IP Address 84.13.222.131
Network Type PPPoE
IP Subnet Mask 255.255.255.255
Gateway IP Address 84.13.208.1
Domain Name Server 62.24.139.6
62.24.134.2
LAN Port
MAC Address 00:1E:2A:23:3D:BE
IP Address 192.168.0.1
DHCP On
IP Subnet Mask 255.255.255.0
Modem
ADSL Firmware Version A2pB023b.d20e
Modem Status Connected
DownStream Connection Speed 21141 kbps
UpStream Connection Speed 1020 kbps
VPI 0
VCI 38
Wireless Port
Name (SSID) Barnes Home
Region Europe
Channel 6
Wireless AP Disabled
Broadcast Name Disabled
Message 8 of 12
jmizoguchi
Virtuoso
You have public IP so all should work....
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 12
Jack_
What browser are you using for configuring the DG834?? If you use Microsoft Internet Explorer you should be OK. Some other browsers have issues with Netgear device menu settings. Make sure you clear the cache and refresh the page when setting up a DG834. Sometimes you are configuring a menu page of a router or modem-router by using a "cached" page, meaning, the changes you have made to the settings do not actually occur. HTH
Message 10 of 12
Benjamin_Barnes
I use firefox but for changing the router/modem i use internet explorer checked it in IE and FF and its exactly the same. Still nothing works. My internet also randomly cuts out for 5 seconds every like 4 hours if that has anything to do with it?
Message 11 of 12
Jack_
Again, most important to perform menu settings after cache and sometimes also history has been cleared. Then start browser again and make your changes.
If you are sure your device does not accept any port forwarding rules, then it becomes time to reflash the firmware and start with a fresh new image in your device.
"internet cuts out" is not very informative.
Problem with wireless or also wired connection?
Try to ping wired to router a responsive IP such as 4.2.2.2 to establish if your modem is online or not.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2906 views
  • 0 kudos
  • 3 in conversation
Announcements
