Reply
Port based VLANs in WNDR3800
josebamartos
Novice
Hi,
I purchased WNDR3800 router for my office. I was trying to create VLANs in the router's web interface and there is no option for that.
I called the technical support and they said that this router can't create any port based VLAN. I would to know if this is a hardware or a software restriction. Have anyone successfully created VLANs with this router? Maybe with OpenWRT or DD-WRT? I can't believe that a full-featured router like this is not capable to create port based VLANs.
I have a VLAN ready in a Netgear GS724Tv3 switch but I need to create the VLAN in the router too for routing and assigning an address to the VLAN network.
Message 1 of 2
josebamartos
Novice
[SOLVED] Re: Port based VLANs in WNDR3800
Thanks to budee in myopenrouter.com, I installed OpenWRT and made all the VLAN configuration graphically using the web interface, without editing any file.
Just create the VLAN (Switch), the interface and the firewall rules.
I installed OpenWRT Backfire 10.03.1 for ar71xx.
Solved Smiley Happy
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2703 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
