Reply
Port forwarding on wndr3700 not working
mvestel
I have an OmniPro II home security system that requires me to log in by opening a port, port 4369. the IP address of the system is 192.168.2.160.
I use a program, PC Access, to log into the system. I can successfully log in when i'm at home on my network, logging directly to the 192.168.2.160 IP address. When i try to log in to the IP address of the router, however, with the port forwarding setup, it will not work.
I've setup the port forwarding to be:
Start Port 4369
End Port 4369
IP address: 192.168.2.160
I dont see a way to enable it or disable it so i assume if its in the list, its enabled. the radio button appears to be just for editing or deleting the service.
Any ideas what is wrong?
Message 1 of 7
jmizoguchi
Virtuoso
Re: Port forwarding on wndr3700 not working
WAN/internet port of the 3700 MUST have public IP (ISP released ) or it will not work
see router setup on my sig below make sure broadband and router is setup correctly
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 7
mvestel
I dont understand what you just said...can you speak in layman terms? what do i do?
Message 3 of 7
jmizoguchi
Virtuoso
That is why told you to read router setup ony sig below
If still can not understand, get some friend help you out
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 7
mvestel
I'm on the forum to get help, wish my fiends were network gurus. they are not.
The router works as does the modem, in so much as it provides the LAN IP addresses and my wireless works.
i dont see anything on your posts about how to set it up so the IP is released. is that a setting on the router? i have a specific router, the WNDR3700.
Message 5 of 7
jmizoguchi
Virtuoso
right or wrong setup will give you internet connectivity. read all the steps , and if you don't come up with questions then you did not read all or just don't understand.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 7
mvestel
I have read your router setup.
My modem is not wireless, it does not act like a router.
my IP is public, it is a cable modem (so i dont have to worry much as you note)
Of course my computer is connected to my switch, connected to the router, which is in turn connected to the modem.
I can log onto my router so i'm connected propertly as you mentioned.
I would challenge you: ask me a question about my setup that will help diagnose a problem. dont just point me to the same info.
my router status, per maintenance is:
Router Status
Hardware Version WNDR3700
Firmware Version V1.0.4.68NA
GUI Language Version V1.0.0.42
Internet Port
MAC Address 30:46:9A:1C:61:0B
IP Address 67.169.45.121
Internet DHCP
IP Subnet Mask 255.255.248.0
Domain Name Server 68.87.76.182
68.87.78.134
LAN Port
MAC Address 30:46:9A:1C:61:0A
IP Address 192.168.2.1
DHCP On
IP Subnet Mask 255.255.255.0
Wireless Port
Wireless Settings a/n
Name (SSID) Vestel_Netgear5GHz
Region United States
Channel --
Mode Up to 300 Mbps
Wireless AP Off
Broadcast Name On
Wireless Settings b/g/n
Name (SSID) Vestel_Netgear2-4GHz
Channel --
Mode Up to 130 Mbps
Wireless AP Off
Broadcast Name On
Wi-Fi Protected Setup b/g/n Configured
Wi-Fi Protected Setup a/n Configured
Message 7 of 7
Discussion stats
  • 6 replies
  • 3249 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
