Reply
Preventing bypass of OpenDNS Parnetal Controls
kwemple
Follower
My son is bypassing our WNDR4500 parental controls via VPN. Is it possible to block his ability to access VPN while maintaining access to my company's VPN?
Message 1 of 2
Mars Mug
Virtuoso
Re: Preventing bypass of OpenDNS Parnetal Controls
If he’s smart enough to bypass by use of VPN, then any steps you take will likely be circumvented, especially since the router has limited capabilities compared to small business grade routers. Even in a large company with an IT team it’s possible for people to bypass and disrupt the security measures put in place, what generally stops them is the consequences which include disciplinary action. You may well find that whatever router you use, your son may always find a way round the obstacles you put in the way, for example temporarily connecting the modem Ethernet cable to a router LAN port could allow him to bypass the router completely.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4444 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
