Reply
Problem with Connecting to Wireless Router.
Oddball1221
Follower
So I have a modem, a router, and wireless devices. So when I connect my wireless device for the first time to the router, it works. If I disconnect from the router and try to reconnect, then it dosen't work. If I reset my router (plug), then the cycle starts again.
I tried to replace the modem, but it temporarily worked.
My router is a Netgear WRG614v7.
Thanks
Message 1 of 4
Mars Mug
Virtuoso
Re: Problem with Connecting to Wireless Router.
We need extra information such as;
What model of modem do you have?
Is the modem DSL or Cable?
What wireless client devices are you using (the devices fitted to the computers etc)?
Do you completely shut down the computers or do they go into ‘sleep mode’?
What method of wireless encryption do you use?
Are you using the Wireless Access List?
Is it only one device that cannot re-connect, do you have others?
Message 2 of 4
mrm1203
I have the WRT614v7 router, me and my roomates have several wireless devices, 4 computers, 2 Playstation 3's, an XBOX360, and smartphones. Everything is getting a connection fine except one computer. The computer in question is says it is connected to the wireless router, but the it cannot access the internet, while all other devices are performing flawlessly. Any ideas on what the problem could be?
Message 3 of 4
jmizoguchi
Virtuoso
1. What model of modem do you have?
2. Is the modem DSL or Cable?
3. What wireless client devices are you using (the devices fitted to the computers etc)?
4. Do you completely shut down the computers or do they go into ‘sleep mode’?
5. What method of wireless encryption do you use?
6. Are you using the Wireless Access List?
7. Is it only one device that cannot re-connect, do you have others?
answer to all
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 4 of 4
Discussion stats
  • 3 replies
  • 4414 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
