Reply
QoS & Uplink bandwith speed problems.
jubjubrsx
Novice
I'm having a real heck of a time with this and basically its boggling my mind....
basically I need to limit my uplink connection. now i found the spot to do it but the router forces a speed check and when i run a test from speedtest.net I get about 35mb down and 6.5mb up(from my laptop)... when i do the check(from the router) it always says my uplink speed is anywhere from 110kbps to 190kbps so i cant really limit the uplink.
is there anyway to fix this?
Message 1 of 3
jubjubrsx
Novice
Re: QoS & Uplink bandwith speed problems.
loaded up the beta firmware and it fixed the problem.
Message 2 of 3
sethfeinberg
@jubjubrsx may I ask which particular beta software you used?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3942 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
