Reply
R4600 Passkey won't work on just 1 PC
Frustratedphd
Hi,
I have an R4600 wifi router that has worked wonderfully for about two years now. We recently updated the passkey, which was fine for 5 of 6 or so devices. My Windows 10 pc laptop though won't connect with an "incorrect passkey" or "can't connect to this network" notification. I verified the passkey was correct multiple times. I forgot the network, changed the password, and reset the router. Again all other devices work but my PC, which still uses other networks fine.
Is there a feature that blocks a device after a minimum number of failed login attempts? I'm struggling to figure out what I'm doing wrong.
Thanks in advance.
Message 1 of 3
Frustratedphd
Re: R4600 Passkey won't work on just 1 PC
Sorry, meant R6400.
Message 2 of 3
Frustratedphd
Turns out all of my other devices we're using a different WiFi band then my PC. Changed the password on the other band too and everything works now.
Message 3 of 3
Discussion stats
  • 2 replies
  • 367 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
