Reply
R6200 - How to unblock IP addresses
nbdiver
Hi,
I am trying to unblock specific IP addresses that are requested in order for my Verizon Network Extender to work. I think I've successfully port forwarded the specific VPN ports that they require to be opened but I don't know how to add a specific ip address. Everything I read says go into the firewall settings under security but my router does not have that option in the manual? Can anyone help as this seems to be a critical piece to get my network extender to work. Thank you.
Message 1 of 10
fordem
Mentor
Re: R6200 - How to unblock IP addresses
I think Verizon is jerking your chain - have they told which in "direction" the port needs to be opened? If not ask them. By default, all outgoing traffic is permitted and all incoming traffic is blocked, unless the incoming traffic corresponds to a prior outgoing request. Port forwarding is only required if you want to permit an unsolicited incoming connection. I suspect the instructions you have been given (open port xyz ect.) are intended for use with corporate firewalls, which are configured differently to consumer firewalls, and whilst the network extender does require these ports opened - in your case they are most likely already open, they were never closed.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 2 of 10
nbdiver
you may be right. This was taken from their website for installation and troubleshooting instructions for the network extender.
The following ports and IP addresses must be unblocked for the Network Extender to work properly.
Ports:
TCP
53
52428
UDP
500
4500
52428
IP Addresses:
Security Gateway IP addresses (sg.vzwfemto.com)
66.174.71.40
69.78.33.132
69.78.33.148
69.78.33.135
69.78.33.151
69.78.33.138
69.78.33.154
69.78.33.164
69.78.33.180
69.78.33.167
69.78.33.183
69.78.95.193
69.78.99.196
69.78.99.212
69.78.99.199
69.78.99.215
69.78.99.202
69.78.99.218
69.78.99.228
69.78.99.244
69.78.99.231
69.78.99.247
Java Messaging Service
69.78.69.199 JMS (jms.vzwfemto.com)
Short Messaging Service Gateway for Unified Communications Software
69.78.69.206 UCM-SMS 1
69.78.69.210 UCM-SMS 2
69.78.69.218 UCM-SMS 4
69.78.69.222 UCM-SMS 5
Global Positioning Satellite Server
209.210.15.73 GPS server (gps.vzwfemto.com)
Message 3 of 10
fordem
Mentor
The critical information is what direction - inbound or outbound.
Message 4 of 10
nbdiver
I should have included the first paragraph, it appears both...
It is necessary to enable Transmission Control Protocol (TCP) and User Datagram Protocol (UDP) (incoming and outgoing) for specific ports and/or unblock specific IP addresses on the modem/router. Refer to the Internet Service Provider (ISP), Network Administrator, or equipment manufacturer for assistance with these settings. Examples of router setup are provided here; however, Verizon Wireless doesn't support 3rd party routers.
Message 5 of 10
MoonValley
Guide
I have the same problem with an ATT Microcell.  The manual for my Netgear R6220 says all incoming ports are blocked by default.
Message 6 of 10
DexterJB
NETGEAR Moderator
Hi @MoonValley,
Have tried performing port forwarding for the Microcell device? If not, then you may refer to the link below for the steps. Also, you will be needing the specific port numbers that AT&T requires to be opened for the Microcell.
http://kb.netgear.com/app/answers/detail/a_id/24046
Dexter
Community Team
Message 7 of 10
MoonValley
Guide
The following are the settings required by ATT:
-DHCP is on
-Data is not restricted from passing through ports 4500 and 500 (AKA Port Blocking).
 -MTU size is set to 1492
-MAC address filtering is either turned off or allowing the MAC address of the AT&T MicroCell IPSec Pass-Through is Enabled
-Block Fragmented Packets is Disabled
-If the MicroCell is connected to a router that is connected to a modem and both the router and the modem have NAT (Network Address Translation) enabled, disable NAT either in the router or the modem.
-Ensure the modem / router is using the latest software (firmware). Please see the manufacturer's documentation.
-TCP/UDP Ports
Note: All ports listed need to be configured for inbound and outbound connections.
-123/UDP: NTP timing (NTP traffic).
-443/TCP: Https over TLS/SSL for provisioning and management traffic.
-4500/UDP: IPSec NAT Traversal (for all signaling, data, voice traffic).
-500/UDP: IPSec Phase 1 prior to NAT detection (after NAT detection, 4500/UDP is used).
-4500/UDP: After NAT detection, 4500/UDP is used
The port forwarding custom service has the following port ranges set for external and internal.  Protocol for all ports is set to TCP/UDP.
123-123,443-443,500-500,4500-4500
 I have set the MTU size to 1492, enabled IPSec pass-through, and set NAT to "OPEN".
There are no entries listed in Port Blocking.
Message 8 of 10
DexterJB
NETGEAR Moderator
Hi @MoonValley,
Have you tried by passing the router and connecting the Microcell straight to the modem and see if it works from there?
Dexter
Community Team
Message 9 of 10
MoonValley
Guide
I took the router out of the loop and connected directly to the cable modem.  The result was exactly the same, so it seems pretty clear that the router is not the issue.  I will circle back with ATT and post here when I have news.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 8260 views
  • 0 kudos
  • 4 in conversation
Announcements
