- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6200v2 Extender?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
R6200v2 Extender?
I have the above mentioned Router which is a Great product. I however had to switch wifi providers and they insisted I had to use their Router and it is was supposed to be so much better and all that other hogwash. Turns out theirs is literal crap but I don't know if I can use mine or if I can use it as an extender maybe. Anyone able to give me any advice or help would get a definate prayer sent up for them. The provider I use is Exede and the "router" is a "Viasat" no other info, no model number or anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R6200v2 Extender?
@WhyspyrGently wrote:
I have the above mentioned Router which is a Great product. I however had to switch wifi providers ...
Do you mean Internet suppliers? (I haven't come across anyone providing wifi as a service.)
If so, you need a modem that works with whatever internet service Exede delivers. DSL? Cable? Satellite? I guess this is what the Viasat box does.
You should then be able to connect your R6200v2 to the modem and use that for local wifi.
We'll need to know a bit more about this anonymous Viasat modem to get much further. If it is a modem/router – does it chuck out wifi and have a set of LAN ports on the back? – you need to to work out how to put it into modem only (bridged) mode to work with the R6200v2.
There is a manual for the R6200v2 somewhere at the end of this link:
>>>> R6200v2 | WiFi Router | NETGEAR Support <<<<
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
