Reply
Highlighted
R6200v2 loses static route on reboot
I have defined a static route on my R6200v2. But it works only until the next reboot of the router. The static route rule is still visible in the web gui but it seems to be inactive, even if "Active" is set. When I deactivate and reactivate the route it works again until the next reboot.
Firmware version is 1.0.3.10.
Any ideas?
Message 1 of 4
Highlighted
NETGEAR Moderator
Re: R6200v2 loses static route on reboot
Hi @nunstruck,
1. Have you tried using another firmware?
2. Have you tried re-flashing the latest firmware?
3. Have you tried resetting the router?
Dexter
Community Team
Message 2 of 4
Highlighted
Hi Dexter,
yes, I've tried all you've mentioned. Same problem also with previous firmware.
I should mention that I'm using this device only as an access point, so the Internet port is not connected. Maybe problem with the default route?
Joe
Message 3 of 4
Highlighted
Guru
If you are using this device only as an access point, can you configure the static route on the other device functioning as the router?
Message 4 of 4
Discussion stats
  • 3 replies
  • 1977 views
  • 0 kudos
  • 3 in conversation
Announcements
