Reply
R6220 Firmware upgrade problem
Deadlock4400
hello everybody,
Netgear AC1200 (Model: R6220) is showing only USB light on it's body, though while start it's shwos all light.
Last time while upgrading the latest firmware, i guess that upgrade was not done properly. Though, this router was being upgraded several times before. and last upgrade time internet connectivity and electricity was alright.
now how can i troubleshoot it and make it alright?
Thanks in Advance
Model: JR6100|AC1200 WiFi Router
Message 1 of 4
Deadlock4400
Re: R6220 Firmware upgrade problem
Is there any way to flash the firmware and make it alright?
Message 2 of 4
antinode
Guru
   That "only USB light" symptom sounds stranger than usual, but you
might try the last-ditch/emergency TFTP recovery scheme:
      https://kb.netgear.com/22688/
   I know nothing, but some reports here suggest that, on Windows, the
built-in command-line TFTP client works better than the "tftp2.exe"
program shown there.
Message 3 of 4
Deadlock4400
thanks a lot for your reply. happy to know the process you showed here. Already that router i sent to warranty, if they fail, i will definitely try your way.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1002 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
