× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6220 Router might be bricked. Need help
Aristillus
Follower
I was doing a firmware update when my power trip. When i try to connect to the gateway ip to do the firmware update, it doesn't load and there is no internet connectivity. The router 1 and 2 is blinking continuously. I think my router has bricked. Appreciate help as im not sure what to do. I tried to use the tft2.exe but it wouldnt work and im not sure what steps have i done wrongly. Im not really good with router so might have a bit of difficulty understanding you guys explanation. Thank you for being patient with me in advance. Bless all!
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: R6220 Router might be bricked. Need help
Hi @Aristillus,
1. Have you tried going through the TFTP process linked below?
http://kb.netgear.com/app/answers/detail/a_id/22688
2. If yes, at what step do encounter an issue?
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @Aristillus,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @Aristillus,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1202 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
