- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6220 - Toss or Continue troubleshooting?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let's cut to the chase, I picked this router up at Costco sometime around April or May as my old ASUS RT-N56U started stumbling my connections consistently despite being 2 years of performing like a champ.
To its credit, the R6220 worked great and fast when it was setup out of the box. I was happy with the speeds on wired and wireless as it reached my connection limit 105 Mbps.
But after reading the security related updates on the router, I said sure lets update the firmware (latest one at the time).
And queue the horrendous performance of the R6220. Wifi connections constantly get dropped, my one PC that is on LAN will at times randomly drop connections to certain programs.
Speed tests on wired drop considerably and Wifi Speeds at 2.4ghz are subpar along with the 5ghz pulling out 50-60 Mbps in the same room as the router.
So I decided to do some reasearch and saw that this router was getting slammed with bad reviews due to connectivity issues and bad firmware. Many of them suggesting to downgrade to V1.0.0.16_1.0.1 and performance was acceptable.
So the question is, what firmware should we be using for stability and what have others done to increase performance?
Or did I make a grave mistake in not investing more money on a nighthawk series and I should just bin this router?
Before I get a generic response about what I have done with the router...
Upgraded to latest firmware: Yes
Factory Reset: Yes
Channel Monitoring: Yes, I have adjusted the router manually if the channel was congested.
Power cycling all network gear: Yes
Number of connected devices: Actively we have 4-5, 1 PC Wired, Chromecast, 2 phones, 1 laptop.
Tried a different router: Not one on hand.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Existedtoxic,
1. What is the firmware version of the router?
2. Have you tried resetting the router?
3. You can try re-flashing the firmware of the router.
4. Are all devices affected (wired and wireless)?
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6220 - Toss or Continue troubleshooting?
Hi @xplicit,
May I know if you have tried re-flashing the firmware? If not, please try doing so then reset and reconfigure the router. Please keep us posted if there are any changes. You may refer to the links below for the steps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dexter I have tried multiple different firmwares and anything above the one I have installed always seems to make my Wifi extremely subpar and my Lan connection to constantly DC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Existedtoxic,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Existedtoxic,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
