- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6230 only getting below 200M speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought R6230 two years ago, my internet speed got upgrade recently to 900M. From the setting of R6230, 5G is up to 867M.
I connected a cable to R6230, it can get 600M, that means my Modem works well, the router already got that speed, just wifi issue.
Already turned off access control, QoS, did factory reset, nothing works.
I understand it wouldn't reach 867M, but it is always below 200M, should it be at least 300M? Feels like something wrong.
Can anyone give me some help?
Thank you very much!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Ookla application is installed from the Play Store. It is not part of a GUI or a web address where you use a browser.
On a good day for Wi-Fi, the 2.4 GHz band will deliver 125+ Mbps to average devices. Similarly, the 5 GHz band will deliver 300+ Mbps to average devices. The numbers in the router configuration page are theoretical link capacity. They are not real world actual.
Make sure the devices you are running the tests from have the most recent device drivers installed.
Next you could experiment with different channel numbers in the bands. Disable Auto channel selection and select channel 11 in the 2.4 GHz band and channel 48 in the 5 GHz band.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6230 only getting below 200M speed
Disable Smart Connect in Advanced -> Setup -> Wireless Setup.
Provide separate SSID names for the 2.4 GHz band and the 5 GHz band. This way you can tell which one you are connecting to.
You may find disabling 20/40 MHz coexistence on the 2.4 GHz band is beneficial. Try it both ways.
Install the Ookla native operating system application for capacity testing.
Please identify the manufacturer and model number of your upstream modem/ONT. Is there a chance it is a combination device with a router?
Make sure your cables are Cat 5e or Cat 6.
If you pay for 900 Mbps download you should get 900 Mbps download at your modem.
You originally posted this in the Nighthawk section. That is where I wrote my answer. The R6230 is not part of the Nighthawk line and your settings may be in different sections.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Kitsap Thank you for the response.
I did the first two already. Different SSID name and disabled 20/40 MHz coexistence. Nothing changed.
The modem I have is ARRIS SURFboard SB6190 DOCSIS 3.0 32 x 8 Gigabit Cable Modem | 1 Gbps Port | 800 Mbps Max Internet Speeds.
The max speed is 800M.
If I connect my laptop to R6230 with a cable directly (not sure if that Cat 5 or 6), I can get 600M from laptop, I think that means Modem or cable is not the problem? Seems R6230 has got 600M speed from Modem, it just cannot send it as similar speed by wifi.
What is Ookla native operating system application? I tested the speed from Speedtest by Ookla - The Global Broadband Speed Test, also Nighthawk app.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh so true.Wifi speeds and Internet speeds are different animals.
It is surprising how many people think their wifi should break the laws of physics.
@poslab might enjoy a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
Especially the bit about your client device.
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@poslabmight enjoy a bit of background reading.
I fully agree. A little education and understanding never hurts!
