× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6230 won't upgrade to latest firmware
jjriv
Follower
I keep getting emails from NetGear telling me I need to upgrade my firmware to Latest firmware version: v1.1.0.92
I am current running V1.1.0.86_1.0.1
When I try to check for a new version from the Internet, both the mobile app and the web admin tools tell me i'm running the latest firmware.
What should I do?
Model: R6230|AC1200 Smart WiFi Router Dual Band Gigabit
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: R6230 won't upgrade to latest firmware
> What should I do?
   Visit http://netgear.com/support , put in your model number, and look
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.
Message 2 of 2
All Replies
antinode
Guru
> What should I do?
instructions.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1478 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
