- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6250 router seems to be slowing down my internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi I have a R6250 router with the V1.0.4.2_10.1.10 firmware. I have been noticing a slow internet connection and I think I have the problem pinned down to the router. I plugged in directly to the modem and was getting around 60 MBPS. When I ran the speed test using wifi, my speed drops dramatically, I get anywhere from 1.5 MBPS to 10 when it is working best. Once in a while I can get up to 25 MBPS. I have tried replacing the cord between the modem and the router, I changed channels, and I reset the router. None of those seemed to make a huge difference. I realize my wifi won't be as fast as a wired connection but this seems ridiculous. Any ideas on what I can do to fix this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I got the problem fixed. I got a new router from my internet service provider, they gave me a R6300 and I experienced the exact same problem. I had a tech come out and he hooked up an older Netgear WNDR 3800 router and it solved my issues, I'm now getting the speed I should be through WIFI. I believe it was a problem with the R6000 series, maybe a firmware issue?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6250 router seems to be slowing down my internet connection
That router should be capable of providing the full ISP rate of 60Mbps depending on the capabilities of the client WiFi devices.
Can you please post details of your modem, manufacturer and model number? If the modem is a DSL type then it may be necessary to reduce the MTU setting for the router, e.g. 1492 or lower (1400 or 1350).
- Mark as New
- Bookmark
- Subscribe
- Permalink
My modem is a Ubee U10C035. It's a cable modem provideded by the ISP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Agolz12,
1. Does the issue affect all wireless devices?
2. What speed are you getting from the devices that are wired to the router?
3. Does the issue happen on both bands (2.4GHz and 5GHz)?
4. have you tried changing the MTU?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. it affects all wireless devices
2. I'm getting roughly the same speeds when wired to router or through router wifi.
3. I don't think my wireless card supports 5 mhz
4. I tried dropping the MTU to 1400 and it didn't seem to make a difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's a new strange layer to this whole problem. I've noticed that between 5-6 each night the wifi almost grinds to a halt. I was clocking less than 1 MBPS through the wifi, when I plugged straigh into the modem I got 60 MBPS. I used Wifi Analyzer and didn't see anything new on the channels and I don't believe any new sources of interference were introduced at that time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried a reset and reinstalling the firmware, the problem persists.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Agolz12,
Try checking for the optimal MTU value then change it to that and please check if it makes a difference. You may refer to the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/19863
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I came back with 1500 which is what my router is set at. Thanks for the help by the way, this is driving me crazy!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
