Reply
R6260 Firmware update crashed ... can't recover
PhilVorb
Follower
Hello my R6260 crashed after a Firmware update has been initiated ...
It is now impossible to recover it , even with the tftpd64 tool..
Any hints
Thanks
Model: R6260|AC1600 Smart WiFi Router Dual Band Gigabit
Message 1 of 3
Guru
Re: R6260 Firmware update crashed ... can't recover
Any hints
Thanks
tftpd64 tool?
do you mean tftp? https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
make sure you enable it in windows 10 if thats what you use.
https://www.thewindowsclub.com/enable-tftp-windows-10
What errors did you get? TFTP is pretty specific to even capitalization/spacing needs to be correct. Did you follow it exactly?
there's also the option of nmrpflash
https://github.com/jclehner/nmrpflash
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
antinode
Guru
   If it's actually "impossible", then you might as well quit now.
   If, on the other hand, you provide an actual problem description,
instead of only your conclusion, then some progress might be possible.
   "crashed" or "impossible" is not a useful problem description.  It
does not say what you did.  It does not say what happened when you did
it.  As usual, showing actual actions (commands) with their actual
results (error messages, LED indicators, ...) can be more helpful than
vague descriptions or interpretations.
   Many people have reported better results using the command-line TFTP
client program which comes with their OS -- What's yours? -- than any
third-party add-on program.  Better error messages, at least.  See, for
example:
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 514 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
